Date/Time: Sun, 19 Jan 2025 12:22:31 +0000
Resetting zig zag study at the start of each session
View Count: 1348
[2014-05-22 16:21:12] |
joeroma - Posts: 43 |
I realize that you have been asked for this feature several times in the past, that support has lot of projects on its plate, and that Anthony said last year that this feature is a bit complicated, but I was wondering if adding this feature is on the horizon. Thanks.
Date Time Of Last Edit: 2014-05-22 16:31:35
[2014-05-22 16:57:01] |
We will see if we could get this done soon.
[2014-06-12 14:07:22] |
Al SC Developer - Posts: 434 |
In ver 1147, the Zig Zag study has a new option: Reset ZigZag At Start Of Trading Day
[2014-06-17 20:02:08] |
Thanks for adding this feature. Greatly appreciated. However, it does not seem to be working properly at the start of the new day. I get one of the two results. In the first link numbers in previous days are not displayed. Only the one number as shown but it is incorrect. In the 2nd link, numbers for previous days are displayed. http://www.sierrachart.com/image.php?l=1403034872903.png http://www.sierrachart.com/image.php?l=1403034761915.png Date Time Of Last Edit: 2014-06-17 20:14:33
[2014-06-17 20:19:12] |
This will be addressed in ver 1149. If you add more days of data or turn off calc on bar close, you can get around the issue in the short term.
Date Time Of Last Edit: 2014-06-17 20:34:29
[2018-04-14 17:14:30] |
User45989 - Posts: 54 |
I realize that this is an older thread, but has there been any movement on the ability to reset the ZigZag for each session? The daily reset is useful and appreciated, but when exporting data, more than one chart (ETH, RTH) is necessary to capture the information. This adds to the risk of user error when examining the data of different symbols. Thank you, |
