Date/Time: Wed, 19 Mar 2025 19:23:36 +0000
CS DATA- ALL SERVICE
View Count: 330
[2022-10-31 16:11:29] |
User421891 - Posts: 2 |
Tengo una cuenta abierta y financiada con NiNJA Trader ( utilizo la plataforma de Ninja para introducir ordenes ) y otra con AMP Global EUROPA ( con Metatrader 5 para ordenes). Ambas con datos en tiempo real CME. ¿Puedo contratar el service pack 10 con Sierra CS DATA? Solo para datos y gráficos en tiempo real no para enrutar ordenes. saludos |
[2022-10-31 17:22:50] |
John - SC Support - Posts: 38806 |
From Google Translate: I have an account opened and funded with NiNJA Trader (I use the Ninja platform to place orders) and another with AMP Global EUROPA (with Metatrader 5 for orders). Both with real-time CME data.
Can I purchase service pack 10 with Sierra CS DATA? For real-time data and charts only, not for order routing. Cheers In order to use Sierra Chart Package 10 with data from our Denali Exchange Data Feed for The CME Group data, you would need to connect your Sierra Chart to one of your live, funded, futures trading accounts in order to qualify for the non-professional exchange fees. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If your connection with AMP uses CQG, then this would be the simplest way to meet the non-professional qualification. If this is the case, then you would follow the instructions at the following link to connect your Sierra Chart to your CQG account: CQG Trading Platform Service: Setup Instructions Then you would go through the Setup Instructions for the Denali Exchange Data Feed for the CME Group data at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
