Date/Time: Wed, 19 Mar 2025 19:53:17 +0000
[Locked] - Error 10053 and 10054
View Count: 349
[2022-10-31 15:59:54] |
User873130 - Posts: 47 |
CQG WebAPI | Connecting to server api.cqg.com | 2022-10-29 12:23:25.165 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-10-29 12:23:25.165 CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2022-10-29 12:23:25.165 CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2022-10-29 12:23:25.165 CQG WebSocket socket (1) | Connecting to IP: 208.48.16.17. | 2022-10-29 12:23:25.165 CQG WebSocket socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2022-10-29 12:23:25.221 CQG WebSocket socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-10-29 12:23:25.221 CQG WebSocket socket (1) | CloseSocket call. | 2022-10-29 12:23:25.221 CQG WebSocket | WebSocket closed. | 2022-10-29 12:23:25.221 CQG WebAPI | WebSocket closed. | 2022-10-29 12:23:25.221 I already tried Restarting PC, 'ipconfig /flushdns', disabled firewall and still doesn't fix it One temporary fix is that I copy directory and paste into another partition and that worked. Are there other alternative?? any help appreciated |
[2022-10-31 17:16:26] |
John - SC Support - Posts: 38806 |
This is being dealt with in this thread: close event error. Windows error code 10053 and 10054 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
