Date/Time: Wed, 19 Mar 2025 18:38:35 +0000
Using Apex trader rithmic, Do I need to activate market depth for exchange as well?
View Count: 649
[2022-10-31 15:27:32] |
User392433 - Posts: 44 |
I have service package 11, but I am using rithmic provided by apex trader since they need it to keep track of positions. The support resources say to activate exchanges for denali as well to get real time + historical, but what about real time market depth? I need market depth but I assume rithmic can handle that. So, is it possible that I just activate top of book on denali and rithmic will provide market depth? Thanks |
[2022-10-31 17:04:02] |
John - SC Support - Posts: 38806 |
Your assumption is not correct. You are either getting the data from us or from Rithmic. You can not get part of it from us and part from them. Therefore, if you are using the Denali Exchange Data Feed and you need the Market Depth data, then you will need to activate Denali exchanges that include the Market Depth data. We see that you have done this, so you should be good. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
