Date/Time: Wed, 19 Mar 2025 19:56:39 +0000
edit c++ code from a dll file
View Count: 696
[2022-10-31 15:00:22] |
User906616 - Posts: 5 |
Hello, I have a .dll study file and I would like to edit the C++ code behind it. Is it possible? Thanks |
Attachment Deleted. Private File |
[2022-10-31 16:51:16] |
John - SC Support - Posts: 38806 |
A dll is a binary file, so no, you can not edit the underlying code. You would need to have the original code, which typically would be in a file with a .cpp extension.
[2022-10-31 17:16:23] |
Alright, thank you And is there any way to convert the dll file back into the cpp file? |
[2022-10-31 17:47:26] |
No, there is not.
