Date/Time: Wed, 19 Mar 2025 18:58:30 +0000
chart background custom label
View Count: 329
[2022-10-31 11:53:31] |
User181801 - Posts: 42 |
Hello and thanks for your help, I am trying to figure out a way to have a transparent custom text label on chart backgrounds. For instance: "tpo merged sessions", or "volume profile monthly". Is that possible? |
[2022-10-31 12:50:52] |
Sierra_Chart Engineering - Posts: 18843 |
You can use this study for this purpose: Symbol Display You can do this by setting the Alternate Symbol Text: Input to whatever you want to display. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
