Date/Time: Wed, 19 Mar 2025 19:56:39 +0000
Stopping Auto-Adjusting Price (Y-Axis) Scale
View Count: 422
[2022-10-31 10:33:44] |
User964846 - Posts: 38 |
Hey Sierra, I would like to stop my Y Axis from resizing automatically when I scroll forward and backward in time. I know I can set the Y Axis to User Defined, but I am wondering if there are other ways as well. Thanks Sierra, I hope you had a good weekend. -Ben |
[2022-10-31 16:27:33] |
John - SC Support - Posts: 38806 |
Besides User Defined there is also "Constant Range". You will find all the information on the different scale range options at the following link: Chart Scale and Scale Adjusting: Scale Range (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
