Date/Time: Wed, 19 Mar 2025 18:44:30 +0000
Cumulative Delta bars.....
View Count: 494
[2022-10-30 18:29:13] |
krypto101 - Posts: 33 |
I was told in the past that Delta indicators/charts don't work the way they are expected to work due to using CQG data. I've seen popular instructors online use Sierra charts along with CQG ONLY and their Cumulative delta charts look just fine- theyre not using Denali/Teton. Broker:AMP Futures |
Attachment Deleted. |
[2022-10-31 00:06:05] |
Sierra_Chart Engineering - Posts: 18843 |
You need to use the Denali Data Feed for the proper data for Cumulative Delta Bars when using CQG. This is the only possibility. Refer to: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-31 05:23:28] |
Yeah I know that, but I'm not going to switch to Denali. I just need someone to explain to me how users of sierra charts w CQG are making Cumulative Delta work for them. I'm still curious and determined to find out a solution to this!
[2022-10-31 09:53:21] |
Using the Denali Exchange Data Feed is easy. You just complete the agreements here and activate the exchange you need: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME The cost is only going to be 1.25 USD per month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-31 09:54:15
