Date/Time: Wed, 19 Mar 2025 18:38:35 +0000
Issue with re-installing 2207 version
View Count: 367
[2022-10-29 04:31:33] |
User182659 - Posts: 3 |
Hello, ive sent you my log, i just can't install older version of Sierra 2207 that i have my old chartbook and spreadsheet. Please advise and thanks in advance.
[2022-10-30 22:02:17] |
Sierra_Chart Engineering - Posts: 18843 |
We see you are running version 2207 but it is not installed into the correct folder. You should install it into this folder: C:\SierraChart2\ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
