Date/Time: Sun, 24 Nov 2024 14:57:20 +0000
G7FX Foundation DOM Chartbook
View Count: 1841
[2022-10-28 21:03:40] |
TheOwl - Posts: 1 |
Hi. I was expecting the G7FX Foundation DOM Chartbook to download when I downloaded Sierra Chart. It did not. Can you guide me how to download the chartbook so I can include it in my Sierra Charts? Thanks
[2022-10-28 22:14:35] |
Your account is not showing that any files are set to automatically download. You would need to ask G7FX about this. For reference, you can view the files set to automatically download by selecting the link for Enabled Studies And Files Set To Download on the main Control Panel for your account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-19 07:24:17] |
User244438 - Posts: 1 |
how do i download the g7fx foundation chartbook
[2024-05-19 15:12:36] |
You need to ask G7FX.
