Date/Time: Wed, 19 Mar 2025 18:51:41 +0000
Data connected but not data on chart
View Count: 539
[2022-10-28 16:33:40] |
User528524 - Posts: 9 |
Good morning my data is connected and other symbols are working but ESZ22-cme is not. Please can you help resolve Kind regards |
[2022-10-28 16:37:03] |
Sierra_Chart Engineering - Posts: 18843 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
