Date/Time: Wed, 19 Mar 2025 18:29:08 +0000
Version 2448 download IB intraday
View Count: 452
[2022-10-28 13:39:54]
User244592 - Posts: 46
I have been staying with 2420 which works fine. Today I used 2448. I set 6 new symbols all good nyse stuff . I could not get any backfill of intraday on any!!!!!The dark blue window that "Downloading Historical Data" does NOT appear on the screen. All symbols were a FAIL. I then went back to 2420 and all have filled in properly. You say its fixed but it is NOT and I will stay with 2420. Maybe 2430 works but I am not sure where it started to go wrong. Just so you know its not fixed.
[2022-10-28 13:46:12]
Sierra_Chart Engineering - Posts: 18843
There is nothing that we need to do regarding this. All of the information is here:
Interactive Brokers Historical Data Issue
There was never a problem we needed to "fix" regarding Interactive Brokers historical data.
Date Time Of Last Edit: 2022-10-29 13:00:52
[2022-10-28 14:16:31]
Why cant you look at why 2420 is working properly and implement that in 2448? You do have a working version in 2420 so whatever you say IB changed is OK in that one. Thats fine, I am not a programmer but it makes zero logical sense. As long as 2420 works I am not bothered, it would be useless to upgrade to a program having no intraday charting.
[2022-10-28 21:56:34]
User584084 - Posts: 268
I get my historical and intraday data from IB. I am running SC Version 2448 with IB TWS offline Build 10.19.1c and have no IB data download issues. Download the latest IB TWS Build 10.19.1c or later. This should fix your IB data issues.
Date Time Of Last Edit: 2022-10-28 23:05:23
[2022-10-29 01:13:45]
Thank you so much, updated both and its fixed.
