Date/Time: Wed, 19 Mar 2025 18:35:12 +0000
Using study to draw line based on information from server
View Count: 331
[2022-10-28 11:52:02] |
User361939 - Posts: 167 |
Hi I am trying to create study that will automatically draw line with text on chart based on text information (TEXT + time of text) from server. Data from server should be updated automatically per (5s) What function should used to transfer data from server into study? Best regards |
[2022-10-28 16:35:47] |
John - SC Support - Posts: 38806 |
How you get the data from your server into your application is completely up to you. Our interface (ACSIL) uses standard C++, so any C++ functionality to get the data can be used. Refer to the information at the following link for the introduction to ACSIL: Advanced Custom Study Interface and Language (ACSIL): Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
