Date/Time: Thu, 26 Nov 2026 22:34:24 +0000
ZNZ22-CBOT [Sim]
View Count: 680
| [2022-10-27 16:21:56] |
| AdamNGB5 - Posts: 1 |
Hi Support, Acct: Merury55 My 10yr Treasury Note Futures DOM is not allowing me to scroll up and down the day's trading range. It is static and this has been going on for a couple of weeks. Thanks in advance Adam |
| Attachment Deleted. |
| [2022-10-27 17:47:47] |
It sounds like you may have inadvertently set the Chart DOM scaling mode to Interactive Scale Locked. Right-Click on the price ladder and select interactive Scale - Move, then try to move the scale up/down by left-clicking and dragging. Refer to the following for more information: Chart Scale and Scale Adjusting: Interactive Scale Move - Move Scale Up and Down For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
