Date/Time: Wed, 19 Mar 2025 19:59:49 +0000
Indices
View Count: 433
[2022-10-27 16:08:33] |
Technical - Posts: 158 |
I cannot tell if I have access to the viewing the SPX in real time using the current configuration I have now. Also, there are many options for the SPX within the find symbol, which is the correct SPX? |
[2022-10-27 17:33:26] |
John - SC Support - Posts: 38806 |
The SPX (S&P 500 Index) is part of the CBOE Indices. You do not have access to this as you have not setup this exchange, and the CBOE does not allow for any data unless it is paid for. If you want the data for the SPX, then you will need to setup the Sierra Chart Exchange Data Feed and activate the CBOE Indices exchange. Follow the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions When you go to open a chart for this, you will find it under the CBOE Indices on the Find Symbol page (the symbol in Sierra Chart is $SPX). Note that you can use both the Sierra Chart Exchange Data Feed and the Denali Exchange Data Feed at the same time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
