Date/Time: Fri, 27 Dec 2024 16:31:14 +0000
[User Discussion] - Parabolas
View Count: 1344
[2014-05-22 07:54:11]
Carl71 - Posts: 125
Can you add Parabolas to drawing tools?
The concept is simple
Take a look at the chart attached
The parabolas is drawing by fixing three points in the chart
The parabola is extended on both sides
This is a powerful tool
Date Time Of Last Edit: 2014-05-22 07:55:23
imageNASDAQ PARABOLA.png / V - Attached On 2014-05-22 07:54:07 UTC - Size: 85.09 KB - 378 views
[2014-05-22 09:21:03]
Carl71 - Posts: 125
http://www.performancetrading.it/AT/Evolventi/EPFormulazione.htm
Le Evolventi Paraboliche sono Curve Polinomiali di ordine 2 la cui comune espressione matematica รจ la seguente: y= a+b*x+c*x^2 nella quale tre coppie delle coordinate x e y individuano i tre punti presso i quali deve transitare la Curva Parabolica descritta dalla formula.
Per tracciare quindi una Curva Parabolica su un grafico occorre selezionare tre coppie di punti sui quali si vuole far transitare la Curva Parabolica.
[2016-03-31 18:56:43]
Tintin - Posts: 23
Hi SC Team,
Is it possible to develop a parabolic curve drawing tool as asked by Carl71 ?
This is indeed a powerful tool.
Most of other chart trading softwares provide such a tool.
This will be definitively a nice feature.
Regards.
Date Time Of Last Edit: 2016-03-31 19:15:29
imagesnip_20160331211153.png / V - Attached On 2016-03-31 19:14:24 UTC - Size: 73.72 KB - 326 views
[2016-04-02 07:11:46]
Marek F - Posts: 244
+1
[2016-04-03 00:10:59]
Tintin - Posts: 23
Hi SC Team,
I just don't understand why this thread is under "user discussion" ?
As said earlier, most other chart trading softwares provide such drawing tool.
Can you please reconsider your position ?
Regards.
