Date/Time: Wed, 19 Mar 2025 19:50:12 +0000
Still getting delayed quotes
View Count: 323
[2022-10-27 15:59:54] |
User133544 - Posts: 1 |
Hello, I have opened an account Edge Clear and funded an account with Dorman as the clearing firm. I am still receiving delayed quotes. What needs to be done so that i can receive real time quotes. Thank you
[2022-10-27 17:09:12] |
John - SC Support - Posts: 38806 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
