Date/Time: Tue, 26 Nov 2024 15:32:03 +0000
maximum amount of bars that can bit squeezed in?
View Count: 1169
[2014-05-22 06:41:53] |
Dom7364 - Posts: 257 |
Is there a maximum number of bars/candles/etc that can be displayed within a window? Attached I am looking at a 250 days 5000 volume candle chart, but I can't go backwards more than as per the screenshot. is this normal behaviour? Thanks http://www.sierrachart.com/image.php?l=1400740756494.png |
[2014-05-23 23:20:07] |
dem_z - Posts: 14 |
+1 would love an infinite zoom out.
[2014-05-24 00:05:21] |
Yes this is normal.
[2014-05-24 04:38:32] |
What is normal? What is the max zoom? Would be useful to know so switching do another time frame would allow to see more with less bar or something like that if it is limited to a number of time periods/bars/data/else.. Thanks |
[2014-05-24 05:02:25] |
One bar per pixel . So the limit is the number of pixels within the chart window minus the margin used for the scaling. So if you increase the time period per bar, then you can see further back in time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-24 05:36:40
