Date/Time: Tue, 01 Apr 2025 22:05:47 +0000
How do I differential different instances of Sierra Chart?
View Count: 694
[2022-10-27 00:52:10] |
User396 - Posts: 55 |
I have multiple instances of Sierra Chart installed in different folders. How do I differentiate windows once they are executed because they look all the same? Is there a way to put the folder name (where it has been executed from) in the top line along with the version information of the Sierra Chart? Thank you Date Time Of Last Edit: 2022-10-27 00:53:18
[2022-10-27 07:21:59] |
User431178 - Posts: 632 |
You can set any text you want in the title bar. General Settings Window: Custom Title Bar Name (Global Settings >> General Settings >> GUI >> Application GUI) |
[2022-12-15 08:36:36] |
virtualcointrading - Posts: 45 |
You can change the application icon as well. https://www.howtogeek.com/75983/stupid-geek-tricks-how-to-modify-the-icon-of-an-.exe-file/ Date Time Of Last Edit: 2022-12-27 16:54:42
[2022-12-15 11:49:35] |
User877753 - Posts: 152 |
You can use some stationary text on the chart mentioning the name of your instance : Chart Drawing Tools: Type Text | Stationary Text |
