Date/Time: Tue, 26 Nov 2024 15:49:57 +0000
Configuring Sierra Chart with broker account and DataFeed account
View Count: 1743
[2014-05-22 06:21:44] |
User98588 - Posts: 2 |
Dear all, I would like to know how could I set my Sierra Chart for trading. I mean, where I should enter the credential ( pass and user related with my broker account) ? Thank you, Regards, Bogdan |
[2014-05-22 18:00:15] |
What trading/broker service are you using?
[2014-05-22 19:31:04] |
I have an account with Stage 5 Trading. After I got out from Simulation mode, I searched for a login tab, where I could enter my user and pass for my real or demo account with Stage 5, but I didn't find any tab.
[2014-05-22 21:47:00] |
Stage 5 uses the OEC trading platform service. Here are the set up instructions for that: http://www.sierrachart.com/index.php?l=doc/openecry.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-22 21:47:16
