Date/Time: Wed, 19 Mar 2025 13:52:24 +0000
Alert for Bill Williams Awesome Oscillator
View Count: 500
[2022-10-26 21:19:55] |
User948434 - Posts: 7 |
Please help me to create an alert for Bill Williams Awesome Oscillator. More specifically, the alert will show the highlighted sign and sound for the color changes from green to red, and when positive is changed to negative or vice versa. Thank you very much for your help. River |
[2022-10-26 21:27:57] |
John - SC Support - Posts: 38784 |
Refer to the following regarding making an alert based on the coloring of a study: Study/Chart Alerts And Scanning: Writing Formulas Based On Color Settings The Bill Williams Awesome Oscillator colors the bar green when it has a higher value than the previous bar and is red when the value is less than the previous bar. Therefore, you start 2 bars back to verify the color of the previous bar and then check the current bar. A Red to Green transition alert would look like the following: =AND(ID1.SG1[-2] > ID1.SG1[-1], ID1.SG1[-1] < ID1.SG1) Where ID1 is the ID of the Bill Williams Awesome Oscillator (you will need to set this to the ID of the study for your setup). We will leave the rest of the Alert Condition for you to work out. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-26 21:28:37
