Date/Time: Mon, 25 Nov 2024 05:41:23 +0000
Closing all open trades multiple symbols
View Count: 1017
[2022-10-26 19:45:04]
User456188 - Posts: 3
How to close all open trades on multiple symbols at the same time?
[2022-10-26 20:35:03]
There is are Control Bar and Keyboard options for Trade Flatten All Positions All Accounts.
Refer to the following:
Control Bar: Customize Control Bars >> Control Bar 1-12 (Global Settings)
Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu)
[2022-10-27 11:02:36]
Trade Flatten All Positions All Accounts function is not working.
I tried the Control Bar button and the Keyboard Shortcuts same result. the flatten only function does for one symbol at a time. I need to click on each chart separately to activate it and do it.
I trade two symbols at the same time and i need to close the 2 positions at the exact time.
I'am on Sim at the moment and the Trade service log is not showing anything and the message log also.
[2022-10-27 15:23:57]
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2023-01-19 14:57:23]
Jeff M - Posts: 21
John, I have Trade Flatten All Positions - All Accounts and Cancel Orders All Symbols All Accounts setup as buttons on my Control Bar. I have the Global Settings>>Chart Trade Settings>>General>>Disable Order Confirmations = Yes. Also, all confirmations are unchecked in my Attached Trade Window Menu. I am still getting a pop up window to confirm closing/flattening positions. Is there another menu somewhere that needs a setting changed so that I do not have to confirm?
Thank you
[2023-01-19 16:25:12]
There is not a way to prevent the pop-up confirmation that comes up when using "Flatten All Positions - All Accounts".
[2023-01-19 19:31:51]
Jeff M - Posts: 21
Not a way currently? Or not a way to implement it ever?
Seems to me if I wanted to flatten all positions all accounts I’d want to do it ASAP without wasting time with a confirmation. I guess that’s just me.
[2023-01-19 22:14:34]
Not a way currently. But we can't say when, or if, we will get to changing that particular pop-up.
[2024-01-05 19:34:27]
n8trading - Posts: 36
Is Trade Flatten All Positions All Accounts intended to also include All Symbols? This does not appear to be working on multiple positions across multiple symbols in Sim mode.
[2024-01-06 10:49:24]
Sierra_Chart Engineering - Posts: 17169
That command will not work in Trade Simulation Mode.
[2024-03-27 15:13:32]
af_99 - Posts: 22
Is there any way than to flatten all positions in Simulation mode? (Whatever will be okay but I can´t see any...).
Thank you very much.
[2024-03-27 16:17:32]
There simply is not an option to close all positions for all symbols and all accounts in Simulation Mode. You would need to do it chart by chart.
