Date/Time: Wed, 19 Mar 2025 13:49:15 +0000
does sierra chart still work?
View Count: 370
[2022-10-26 16:04:18] |
02108 - Posts: 28 |
Last week there was no historical data, no one knew the problem and last Thursday it was back to normal. this week there was no historical data again, and now nothing works, if I update the chart it erases everything on it. I know that sierra chart is perfect and it's probably someone else's mistake, but does anyone know something I can do or just not use this platform anymore? |
[2022-10-26 16:24:09] |
Sierra_Chart Engineering - Posts: 18841 |
Yes Sierra Chart is working fine. You should be asking whether Rithmic is working properly and there are issues with Rithmic recently. There are no problems at all with Sierra Chart. The issues you are having are with Rithmic. Refer to the information here: Rithmic Trading Platform Service: Rithmic Support Policy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
