Date/Time: Wed, 19 Mar 2025 13:44:14 +0000
Import Global Graphics Settings to individual chart graphic settings
View Count: 371
[2022-10-26 15:07:28]
funbun - Posts: 90
I try to change one element on an individual chart but for that I have to tick off the "Use Global Graphics Settings instead of these".
The problem is that all graphics settings are reverted back to the original default settings (and not the current Global Settings).
So if I do want to change one graphics element, I have to go over all other elements and change them as well, which is very time consuming, especially if I have to do that for 5 charts.
Is there a way to import my saved Global Graphics Settings to the individual chart settings so that I don't have to set again each and
every parameter?
[2022-10-26 17:07:30]
John - SC Support - Posts: 38782
Sorry, but there is not a way to do what you are wanting. You will have to change all the other chart specific settings to match your global settings.
We have had several requests for this and it is something we want to do, but it simply has not made it as a high-enough priority.
