Date/Time: Wed, 19 Mar 2025 13:44:14 +0000
Study was working fine and then stopped
View Count: 370
[2022-10-26 14:10:13] |
User411320 - Posts: 306 |
below are 3 pics. one showing how the study over lay is blank but still printing some signals, othe pics in the main chart it's pulling from and other pic is side by side charts showing one missing a signal
[2022-10-26 16:56:28] |
John - SC Support - Posts: 38782 |
We see one issue which apparently involves the Study/Price Overlay where it appears you are trying to overlay the Fisher Transform from Chart #9 to Chart #6 and it is not showing up in Chart 6. Is this correct? With regards to this, one of the things that is odd is that the data for the Fisher Transform in Chart #9 shows 0.00 values in the region header, which is not the data that is showing. So there appears to be something wrong on Chart 9. Recalculate the chart and see if it resolves your issue - select Chart >> Recalculate to do this. We are not sure what you are trying to show relative to the Main Price Graph and the pink bars. We would need more information for this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-26 20:55:28] |
closing sierra and opening it up again fixed it
