Date/Time: Wed, 19 Mar 2025 13:46:49 +0000
Slow data lags and updates only every 3-5 sec
View Count: 342
[2022-10-25 23:10:32]
lovelivelaught - Posts: 68
Hello
I have all my charts going slow with data updates every 3-5 sec. Also it freezes the screen every time I want to open any new windows. If I want to move a chart it lags behind by 3-5 sec.
The problem started right after I try to use user contributed studies. At first it froze all my screens and then it took awhile to reset all my charts to initial state.
What I did after it happened -
-I deleted the chart that I used for user contributed studies and restarted the platform and my computer. It did not help.
-I updated chart update interval in milliseconds to 2000, it did not help
-I tried to create a new chartbook and on a first chart I created there was same problem again so I stopped creating a new chartbook.
-I updated my platform to a new version 2448, it did not help
-I tried to search your board for any solutions but did not find anything related to my issue.
The problem started right after I used user contributed study, there was few indicators that I wanted to try. Also I would like to note that I am using user contributed studies for a while such as ECIvwap Bracket and ECIvwapAnchor and I never had such a problem before. I do not use any other custom studies, only sierra chart studies.
Thank you in advance for your help.
[2022-10-26 09:10:10]
Sierra_Chart Engineering - Posts: 18841
Run Sierra Chart in Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
And refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart
You definitely should not have a performance issue with a single chart without any studies.
Also refer to other items on this page:
