Date/Time: Wed, 19 Mar 2025 13:46:49 +0000
How do I move the Candle to the right... so it's in the center?
View Count: 566
[2022-10-25 19:04:59]
User275302 - Posts: 52
Hello, I'm trying to have my Candle be between two Numbers Bars. Instead it seems to be clinging to the right side numbers bar and not in the center. I've tried adjusting everything including the Spacing Adjustment Value and the Chart itself. Any help would be much appreciated. Thanks.
imageCandle Problem.PNG / V - Attached On 2022-10-25 19:04:18 UTC - Size: 62.37 KB - 123 views
[2022-10-25 21:06:23]
Sierra_Chart Engineering - Posts: 18841
There is not a way to control this. It looks like you are overlaying price bars on a Numbers Bars chart. The two studies are not necessarily going to align.
[2022-10-25 21:19:18]
John - SC Support - Posts: 38783
Use a different spacing option for the Numbers Bars, as there are options with up to 4 spaces. Refer to the following:
Numbers Bars: Numbers Separator Character
[2022-10-25 23:36:16]
thanks for the help everyone!
