Date/Time: Wed, 19 Mar 2025 13:44:11 +0000
Orders cling together
View Count: 355
[2022-10-25 15:29:14]
User613910 - Posts: 46
Hi, during trading I like to manage my trades individually also when I step in with 2 or 3. But in Sierra when I enter multiple trades they (orders) tend to cling together and there is no way I can separate them. I don't want that. Especially when scaling in and out. I can't find any way to manage that in a easy way. Can you give me some direction?
Thanks,
Anita
[2022-10-25 16:36:35]
John - SC Support - Posts: 38782
In terms of the primary order, these are always going to be consolidated into a single position line. Refer to the information here:
Trading Information Windows: How Average Price for Positions Is Calculated and Used
If you want your Attached Orders to be separate, then you would NOT want to use the Scale In and Scale Out options. Refer to the following (and the section after it):
Attached Orders: Scaling Out
