Date/Time: Wed, 19 Mar 2025 13:52:23 +0000
Exporting Depth of Market information to txt file
View Count: 353
[2022-10-25 08:43:01]
User846000 - Posts: 28
I'm trying to do a quantitative study of data by exporting tick level data, but I'd also like to export the levels of market depth, is this possible using the standard export method or is there some settings I need to get correctly adjusted?
Tim
[2022-10-25 15:52:19]
John - SC Support - Posts: 38784
There is not a way to export the Market Depth data. You would have to access the data using a Custom Study and then output through your program. Refer to the following:
ACSIL Interface Members - Historical Market Depth Data (c_ACSILDepthBars)
