Date/Time: Wed, 19 Mar 2025 13:52:23 +0000
How to save composite profile?
View Count: 474
[2022-10-25 07:53:03] |
User762633 - Posts: 1 |
Hi, Everytime I merge profiles into composite and change symbol they go back to normal. I tried save chartbook, save all but still same results. I want my composite profiles to stay merged all the time even when I change symbol or relaunch sierra charts unless I undo it. Thank you |
[2022-10-25 08:20:39] |
Sierra_Chart Engineering - Posts: 18841 |
Changing the symbol is going to reset TPO profiles. If you do not change the symbol and you save the Chartbook, close the Chartbook, and reopen the Chartbook, then all splits and merges will be retained. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-25 08:21:24
