Date/Time: Wed, 19 Mar 2025 13:55:01 +0000
Denali CME Datafeed
View Count: 732
[2022-10-24 14:14:45] |
doctor.scalp - Posts: 18 |
Hello support, I've switched my CQG datafeed to Denali last week and I'm also evaluating Package 12. Now I'm only using CQG for order routing. I'm also using bookmap and Rithmic datafeed and I can see some lagging on the denali datafeed if I compare it to Rithmic (on ES) with bookmap. My SC DOM update interval is 25 ms like Bookmap and I don't have any studies on it. I'm using SC v2448(43911M). Can you confirm that with this configuration I should normally have the best performance ? is there any limitation when we're in evaluation mode ? I can try to make a video with both feed if needed ? Regards, |
[2022-10-24 15:51:39] |
https://youtu.be/7Cf2SbfQlhs (just make multiple pause in the video you'll see sierra is always behind) Date Time Of Last Edit: 2022-10-24 15:55:45
[2022-10-25 13:24:28] |
Sierra_Chart Engineering - Posts: 18841 |
We apologize for the delay. How many charts are open in Sierra Chart at the time of that video?
[2022-10-25 16:20:41] |
10 Charts Open at the time of the video. Today I've done a new one with only : ES feed and one DOM on each platform (so no charts). https://www.youtube.com/watch?v=xwnfi3qjJyQ It's the same. SC is a little bit behind. I've also made a recording on NQ to see what happen on a thin market. The latency is more visible. https://youtu.be/T5ThK5B3ZLw It's not a big deal but I was thinking that SC with Denali will be the fastest DOM so far it's not the case at least for me. |
[2022-10-25 22:01:29] |
Go over the items here: Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds See if you notice a difference by reconnecting to the data feed and connecting to a different server: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-25 22:01:41
