Date/Time: Wed, 19 Mar 2025 13:41:46 +0000
Unable to keep Chart DOM on screen
View Count: 441
[2022-10-24 14:04:58] |
User707404 - Posts: 34 |
I am creating a 233 ES chart and a 699 Chart side by side. I then go to FILE to open a trading Dom for the chart. Once I do that the DOM shows up but then when I try and click on the existing chart the DOM disappears and I can't find it anymore? It as working fine last week. This just started this morning.
[2022-10-24 21:30:15] |
John - SC Support - Posts: 38782 |
You have two options for how to handle this depending on how you want things setup. The first option is to set the option on the Trade DOM for Window >> Always on Top. This will keep the Trade DOM always on top of all other windows. Refer to the following: Window, CB and CW Menus: Always on Top (Window) The other option is to select Window >> Attach Chart Window to attach the Trade DOM to the main graphics window (which it sounds like your other charts are) that way if you tile your charts you will see your Trade DOM in the graphics area with the other charts. Refer to the following: Window, CB and CW Menus: Detach/Attach Window (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
