Date/Time: Wed, 19 Mar 2025 13:41:47 +0000
resize text-rows within a DOM-Footprint-window.
View Count: 339
[2022-10-24 07:21:31] |
User408639 - Posts: 70 |
Moin Moin. One shortie.: My notion was off.: I did not resize a chart but rather the DOM-Text-Windows NV created within a chartbook, so.: resizing the DOM-windows NV created for us in Sierra-Chart, all my the lines are being resized by their character-sizes. I do not see _more_ DOM/Footprint lines. Does anyone know, how to configure this. Clicking ctrl/shift/alt-combinations whilst mouse-scrolling does not have any effect. _Tschüß, __Michael. Date Time Of Last Edit: 2022-10-24 07:21:56
[2022-10-24 17:29:28] |
John - SC Support - Posts: 38782 |
You have to adjust the scale by using the Interactive Scale Range. Refer to the following: Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
