Date/Time: Wed, 19 Mar 2025 13:44:11 +0000
trying to decrease CPU usage
View Count: 535
[2022-10-24 06:43:56]
User299107 - Posts: 60
Hi
I've reviewed the documentation re High CPU and it would seem that
currently I have 2 charts - one is a 24 hour session chart and the other is a day session chart. I am using the Study/price overlay Study in the 24 hour chart to reference HLOC studies in the day session. However, the CPU usage is higher than I would like. Is there an alternative method of drawing these lines (rather than manually).
Cheers
Eliza
[2022-10-24 09:01:33]
Sierra_Chart Engineering - Posts: 18841
You first need to determine what is causing the high CPU usage. None of this sounds like an issue.
What other studies are on these charts?
[2022-10-24 09:18:46]
simple spreadsheet formulas. regression channel, time line, bid ask volume, session min.max
When I say High CPU, its 8% for each instance.(3). I split into 3 as one instance was running at 15%
Chart Display is 400ms
[2022-10-24 10:43:56]
Are you noticing the user interface of Sierra Chart, to be less responsive than you want with the current configuration?
[2022-10-24 10:50:31]
It was less responsive on Friday under the One Instance setup - that is why I change to 3 instances over the weekend. I thought it would drop the CPU usage more than it has. I will monitor performance under current set up and if there is an issue I will create another support ticket.
