Date/Time: Wed, 19 Mar 2025 13:55:01 +0000
Red highlights on positive values on number bars
View Count: 376
[2022-10-23 21:00:45] |
7080551385 - Posts: 15 |
I've been unable to figure out how to make the positive values of VOLUME and the positive value of VOL/SEC on the Number Bars Calculated Values - it only highlights the background in green instead of red in response to close of red candle bars. Do you have such function on this? See attached file.
![]() Attachment Deleted. |
[2022-10-24 16:53:12] |
John - SC Support - Posts: 38785 |
The Numbers Bars Calculated Values does not have a way to color the cells based on the Up/Down of the associated bar. You only have options to choose a specific color, or to color based on the value percentage (so you can pick out a certain percentage range easily by the coloring).
[2022-10-24 22:53:22] |
Thanks, in answering. In that case, as part of my feedback, do you have any plan on including this feature in the future? |
[2022-10-25 14:44:24] |
We take all suggestions, but we can not say when we will get to any particular item.
