Date/Time: Wed, 19 Mar 2025 13:52:23 +0000
Importing a chartbook ( using a mac computer )
View Count: 527
[2022-10-23 20:06:22] |
User721265 - Posts: 6 |
hi i have dowloaded a chartbook on my mac that i want to transfer to Sierra chart Data folder so that i can open it on SIerra chart . Can you please guide me on how to do that ? Note i have already downloaded Sierra Chart on my computer through Crossover . All is working well ... thank you for help and have a great day . |
[2022-10-24 00:21:34] |
User584084 - Posts: 268 |
Open up the Crossover App. 1) Find the "Sierra Chart" app listed in the left sidebar under Crossover, Home, Bottles. Right Click the "Sierra Chart" name. Find the "Open C: Drive" Menu item and click it. Or 2) Go to the Crossover Menu at the top of the Mac screen. Click on the "Bottle" Menu item. Find the "Open C: Drive" Menu item and click it. A window with the "drive_c" directory will open up if you installed Sierra Chart to the C directory in Crossover. You should see the "Sierra Chart" directory. Double click it and double click the "Data" directory. Locate the "Finder" icon in the Mac toolbar, Right Click it and Select "New Finder Window". Find your downloaded chartbook. Copy the chartbook from the Mac "Finder" directory to the "drive_C" / Sierra Chart / Data directory. |
[2022-10-26 10:01:50] |
Sierra_Chart Engineering - Posts: 18841 |
Save the Chartbook file to C:\SierraChart\Data And then you can open it: Chartbooks (Workspaces): To Open a Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-26 10:02:17
[2022-10-26 10:46:04] |
Yes
