Date/Time: Wed, 19 Mar 2025 13:52:24 +0000
Exporting Bid / Ask Prices
View Count: 485
[2022-10-23 05:56:46] |
pourhadi - Posts: 3 |
Hi, When I export tick / bar data for a contract like MES continuous, it contains bid and ask sizes. Is there any way to also include bid and ask prices? Thank you |
[2022-10-23 19:43:05] |
Sierra_Chart Engineering - Posts: 18841 |
You can do this by using this study: Bid & Ask Prices And then using this command: Edit Menu: Edit >> Export Bar and Study Data to Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
