Date/Time: Wed, 19 Mar 2025 13:49:14 +0000
Daily ATR value and 14 range ATR in every different chart- NASDAQ
View Count: 375
[2022-10-22 12:17:16] |
User723840 - Posts: 3 |
Hi, I'm able to display the value of the daily ATR for the day and last 14 day using text display. Would it be possible to have that same data ( the daily data) on a 5 min chart? Thanks. |
[2022-10-24 14:40:32] |
John - SC Support - Posts: 38784 |
In general, to get data from one chart to another chart you would use the Study/Price Overlay. Refer to the following: Study/Price Overlay Study If you just want to to display the information as text in another chart, then you would use the Text Display for Study from Chart study. Refer to the following: Text Display For Study from Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
