Date/Time: Wed, 19 Mar 2025 13:57:46 +0000
Default setting for charts
View Count: 648
[2022-10-21 18:32:26]
User409050 - Posts: 22
Hi Support Team,
is there a way for me to set a couple of settings as default settings when I open a chart. For example, I want to have region dividing lines and my favorite chart type is candlestick.
[2022-10-21 19:34:20]
John - SC Support - Posts: 38786
You would need to use a chart that is already setup the way you want and then duplicate it and update the symbol. Or you can create a "Template" chart that you use for this purpose. Refer to the following:
Using Chart Templates: Duplicating Charts / Template Charts
[2022-10-22 16:54:20]
Hi John, thank for your reply
Could you please help me with one more question.
Is there a study that can tell if the highest price or lowest price for a closed bar is reached first?
I can possibly write an ASCIL function looking into Time and Sale records to know but it's complicated and slow.
Thank you
[2022-10-24 15:14:37]
There is not a study that does this and we can not think of a way to do it using existing studies, as there is not a way to capture the intrabar information. It is really something you would have to create a custom study for.
[2022-10-26 12:51:19]
Sierra_Chart Engineering - Posts: 18841
You can only tell this through a lower timeframe per bar chart:
You can then reference that other chart:
Referencing Other Time Frames and Symbols When Using the ACSIL
