Date/Time: Wed, 19 Mar 2025 13:46:49 +0000
Live data
View Count: 477
[2022-10-21 16:35:02] |
Jason Cheyney - Posts: 1 |
I need help connecting my ninjatrader brokerage account so I can get live data.
[2022-10-21 18:21:36] |
John - SC Support - Posts: 38783 |
If you are setup to use CQG for your order routing with Ninja Trader, then you would follow these instructions to connect your Sierra Chart to your CQG account: CQG Trading Platform Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-23 20:44:00] |
User90125 - Posts: 715 |
Once connected to SC via CQG order routing, how are NinjaTrader customers able to trade directly from Sierra Chart? Which data feed should be activated or used to do so - CQG, Denali or Teton? |
[2022-10-24 12:23:08] |
SC Support - Posts: 1943 |
Hi Jason Cheyney, the system is recognizing that you have connected to your Futures Trading Account at Interactive Brokers, connecting to Interactive Brokers each month, like you have done, verifies you as a Non-Professional. In your case you don't need NinjaTrader Brokerage when you have your Interactive Brokers Account. Now please activate the CME Group Exchanges that you want Real-time Data for, you can do that via #3 here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME |
[2022-10-24 12:43:19] |
Hi User90125, If you will be using the Denali Exchange Data Feed integrated with CQG WebAPI Order Routing because the CQG WebAPI Login Credential are what you received from NinjaTrader, follow the instructions here: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services (note: the key element of the set-up instructions is step #5, please enable [Common Settings]: "Allow Support for Sierra Chart Data Feeds"="Yes") User90125, we would always like to see you use our Real-time Exchange Data via Denali, even when you are using CQG WebAPI Order Routing or Rithmic Order Routing, the documentation above speaks to that configuration. Denali Data is superior to all the others available on Sierra Chart When it comes to using Teton Order Routing, the following Brokers are supporting the service, see #2 here: Sierra Chart Teton Futures Order Routing: Setup Instructions |
[2022-10-24 15:24:14] |
Using the CQG WebAPI Login Credential should satisfy the monthly login requirements for a Verified Trading Account, correct?
[2022-10-24 15:33:02] |
User90125, Yes, those CQG WebAPI Login Credentials and the set-up instructions below will connect you to your Futures Trading Account and so verify your Non-Professional status. CQG Trading Platform Service: Setup Instructions Date Time Of Last Edit: 2022-10-24 15:33:19
[2022-10-24 16:03:51] |
Francisco2022 - Posts: 1 |
I'm having issues with connection. The connection area to activate is not working
[2022-10-24 16:37:29] |
Perhaps your issue is that you don't currently have Sierra Chart Usage Time: Ending Date: 2022-10-22 To get more Usage Time, see here: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit Description of Service Packages and Pricing: Multiple Month Purchase Discount |
