Date/Time: Wed, 19 Mar 2025 13:49:15 +0000
Teton CME Order Routing
View Count: 510
[2022-10-21 16:34:56]
User309800 - Posts: 2
Hi team SC,
I am planing to open an account with Click Futures. They informed me that they support Sierra Chart trading platform.
1.Do you connect with Click Futures so can I use the Teton service?
I wish to activate the Integrated Sierra Chart with Advanced Features (Service Package 11) + Denali Data Feed and Exchange Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading. accounts.
2. The question is: I have to inform the broker that I want to use Teton service and after the set up of the account with the brocker I have to communicate all the details to you (SC) ?
Thank you and kind regards
[2022-10-21 16:55:14]
Sierra_Chart Engineering - Posts: 18841
1, 2. Do you know what clearing firm they use?
[2022-10-24 15:24:45]
They are using Ironbeam for clearing
Thank you
[2022-10-25 22:03:30]
Yes Teton order routing will be supported by them.
You just need to follow through the instructions here:
Sierra Chart Teton Futures Order Routing: Setup Instructions
