Date/Time: Tue, 26 Nov 2024 15:31:02 +0000
Why is there a messed up chart? (see attachment)
View Count: 1656
[2014-05-21 16:51:29] |
User59863 - Posts: 36 |
Why is there a messed up chart instead of the normal candles? Got good normal chart until 22:50 PM onwards when got above |
messed-up-chart-GBPJPY.png / V - Attached On 2014-05-21 16:49:09 UTC - Size: 53.49 KB - 376 views |
[2014-05-21 17:38:30] |
Zosimus - Posts: 345 |
I guess it is caused by the study that draws those Lines on the region of the price. Try hiding this study and see if the problem stops. if yes then you will have to change the SCALE settings of this study.Try Changing it to Same As Region. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#ScaleRange |
[2014-05-21 18:07:16] |
Re-download the data from before that bar with the data error, following the instructions in help topic 2.1.2 here: http://www.sierrachart.com/index.php?l=doc/helpdetails2.html Let us know if that resolves the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
