Date/Time: Wed, 19 Mar 2025 13:49:15 +0000
Attached Orders Help
View Count: 411
[2022-10-20 21:19:06]
Sergio Hernandez - Posts: 23
Hi Support Team,
Is it possible to have a bracket that will consist of 3 orders ( 1 primary and 2 child orders) with 1 stop for all, but only 1 target for the primary order? Ideally I would like to have a pre determined target / 1st scale out @ at 3 points & be able to scale the other two at my discretion dependent on the situation. I reviewed "attached order" section on the website, but no luck on finding a way on how to do that.
[2022-10-21 15:46:15]
Sierra_Chart Engineering - Posts: 18841
Yes this is supported. Refer to the attached Trade Window configuration. Instructions:
Basic Trading and the Trade Window: Using a Trade Window Configuration File Provided to You
Date Time Of Last Edit: 2022-10-21 15:46:41
attachmentTradeWindowConfiguration_SH.twconfig - Attached On 2022-10-21 15:44:50 UTC - Size: 4.87 KB - 279 views
[2022-10-25 13:55:29]
The bracket worked exactly how I wanted. Appreciate the help!
