Date/Time: Wed, 19 Mar 2025 09:52:46 +0000
help question
View Count: 350
[2022-10-20 17:46:10]
User427561 - Posts: 217
i keep gettin a syntax error with the following formula, and i dit see anything wrong with it can you look k at it and advis- thanks:
=and((id27.sg1>id27.sg2),(id3.sg1<id3.sg1[-1]))
[2022-10-20 20:41:34]
John - SC Support - Posts: 38782
There is nothing wrong with this for an Alert condition, as long as you have a study with ID 27 and another with ID 3.
If you are trying to use this in a Spreadsheet, then you need to understand that the syntax for the Spreadsheet is different from that used for Alerts, and the given formula is only valid for an Alert. Refer to the following for spreadsheets:
Working with Spreadsheets: Introduction
