Date/Time: Tue, 26 Nov 2024 15:44:55 +0000
Disconnection from OEC
View Count: 1182
[2014-05-21 16:30:38]
NumbersBars - Posts: 141
Just to confirm if this is OEC issue. I got disconnected..
Here is the log:
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-05-21 16:28:42
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-05-21 16:28:42
The network socket is connected. | 2014-05-21 16:28:43
Starting SSL connection on the socket. | 2014-05-21 16:28:43
SSL socket is connected. | 2014-05-21 16:28:43
OEC FIX Trading: Sending the Logon message. | 2014-05-21 16:28:43
OEC FIX Trading: Received a Logout message. | 2014-05-21 16:28:43
OEC FIX Trading: Sending a Logout message. Text = Received Logout message. | 2014-05-21 16:28:43
SSL shutdown indicates not able to send 'close notify'. | 2014-05-21 16:28:43
The SSL socket was shut down. | 2014-05-21 16:28:43
The SSL socket object has been freed. SSL state is now disconnected. | 2014-05-21 16:28:43
Socket has been shutdown and closed. | 2014-05-21 16:28:43
OEC FIX Trading: Logged out and disconnected. | 2014-05-21 16:28:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-21 16:28:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-21 16:28:43
Disconnected from Open E Cry. | 2014-05-21 16:28:43
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-05-21 16:28:43
File >> Disconnect selected. | 2014-05-21 16:28:44
Disconnected from Open E Cry. | 2014-05-21 16:28:44
[2014-05-21 16:33:35]
snillumat - Posts: 29
same problem here. just started 30 min ago
[2014-05-21 16:40:06]
David-G - Posts: 21
Sierra Support,
I too seem unable to get my Sierra Charts up and running. Is this some general problem for your OEC clients at the moment? Earlier today when I was using my desktop I had no problems connecting to my Sierra Charts but now (that I am out) using my laptop I am unable to connect.
Is this a general problem that your OEC clients are facing or is this a problem with my laptop?
[2014-05-21 16:47:02]
Being there are several reports of this, this is an OEC issue.
We will let OEC know now.
[2014-05-21 16:48:18]
avifutures - Posts: 59
The same here:
OEC FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-05-21 19:47:11
Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-05-21 19:47:11
The network socket is connected. | 2014-05-21 19:47:11
Starting SSL connection on the socket. | 2014-05-21 19:47:11
Problem connecting to SSL Socket. Error=5. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2014-05-21 19:47:11
The SSL socket connection failed. | 2014-05-21 19:47:11
The SSL socket object has been freed. SSL state is now disconnected. | 2014-05-21 19:47:11
Socket has been shutdown and closed. | 2014-05-21 19:47:11
OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-05-21 19:47:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-21 19:47:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-21 19:47:11
Disconnected from Open E Cry. | 2014-05-21 19:47:11
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-05-21 19:47:11
[2014-05-21 16:49:14]
We have let OEC know about this.
[2014-05-21 16:53:20]
Just quick update, Connection is up now
