Date/Time: Tue, 26 Nov 2024 15:24:12 +0000
Can't Login to my account. Get this error message
View Count: 1078
[2014-05-21 16:17:19] |
sparky36 - Posts: 21 |
HTTP Error: HttpSendRequest failed: (2) The system cannot find the file specified Note: I am using version 828 |
[2014-05-21 16:42:12] |
This usually means Internet Explorer is set to work off-line. Refer to section 2.2 here: http://www.sierrachart.com/index.php?l=doc/LoginInstructions.php#LoginProblems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
