Date/Time: Mon, 25 Nov 2024 20:47:22 +0000
Broker
View Count: 330
[2022-10-20 13:20:35] |
User653923 - Posts: 52 |
Hi Sierra chart support team. Can you please give me some information in choosing CQG routing and broker as AMP? I already have Denali feed for my data. Thanks a lot. |
[2022-10-20 14:33:21] |
John - SC Support - Posts: 36278 |
We are not sure what you are asking for, as it sounds like you are going to use AMP for your broker with CQG for your order routing. In this case, you would then follow the instructions at the following link to connect Sierra Chart to your CQG account: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-20 14:33:44
[2024-02-01 13:18:49] |
Hi there! I am trying to activate "CME With Market Depth for Non-Professional Trading Accounts" but could not find it. I will really appreciate if you help me locate it or activate it on my behalf. I have added funds in my account. Thanks a lot! |
[2024-02-01 15:48:29] |
You can activate/deactivate the CME Group exchange options at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges The "CME with Market Depth for Non-Professional Accounts" costs $12.50 per month. You will need to add funds to your account to be able to activate this exchange. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
