Date/Time: Wed, 19 Mar 2025 10:09:48 +0000
DOM chart missing information
View Count: 471
[2022-10-20 08:34:32] |
User948261 - Posts: 1 |
Good Morning. My DOM chart only shows two proceeding number ones in both the buy/sell columns. I'm using the SC Data setting and as far as I know I did purchase the correct package. Number bars (Footprint) work just fine. How can I get my DOM chart to display all of the correct information?
[2022-10-20 13:07:22] |
Sierra_Chart Engineering - Posts: 18841 |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Although you are paying a CME exchange fee you are still receiving delayed data , however this is not relevant to the particular issue you are having. Information about this: The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement Consider the above solution to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-20 13:08:30
