Date/Time: Wed, 19 Mar 2025 13:52:25 +0000
High Low
View Count: 440
[2022-10-20 03:54:54]
User841161 - Posts: 263
I am trying to have a line drawn for high and low of past 20 trading days. Using Period OHLC-Variable Period Study. For some its drawing 2 sets of lines instead of 1. Looks like only drawing over 10 day and not 20 days.
Date Time Of Last Edit: 2022-10-20 03:55:49
attachmentHighLowTest.Cht - Attached On 2022-10-20 03:54:39 UTC - Size: 3.37 KB - 181 views
imageHighLowTest.png / V - Attached On 2022-10-20 03:55:42 UTC - Size: 240.56 KB - 105 views
[2022-10-20 14:08:52]
John - SC Support - Posts: 38784
You need to increase the Number of Days to Calculate to at least 30.
[2022-10-24 19:25:51]
Changed to 25 Days to Calculate. It appears to be calculating right, but horizontal lines only drawing 10-11 days.
imageOHLC-Var10-24.png / V - Attached On 2022-10-24 19:25:38 UTC - Size: 249.87 KB - 96 views
[2022-10-25 14:08:06]
Increase the number to 40, and you will see that the previous period covers the 20 days and the current period is building from there.
