Date/Time: Sun, 27 Sep 2026 06:10:45 +0000
Request Comma's in Spreadsheet Number format
View Count: 625
| [2022-10-19 15:43:58] |
| JohnR - User831573 - Posts: 338 |
I looked around, but did not find anything to allow me to specify comma's as a separator within a large number. Specifically, I am looking at a column of Volume #'s. It appears I am only allow to choose from the list of formats supplied. Using commas is not one of them and neither is the ability, like in Excell to specify a custom format. To display As Use this code 12000 12,000 #,### My issue is looking at large volumes and trying to easily distinguish 8 mil from 80 mil 8000000 80000000 vs 8,000,000 80,000,000 using the second set of formats it is quick and easy to know what I am dealing with. If I get around to more automation, this is not an issue, but in my current level of usage, I need to do a fair amount of things manually / visually as I select symbols to trade. Please advise if this is possible, and I did not search enough. JohnR |
| [2022-10-19 20:53:50] |
| John - SC Support - Posts: 48028 |
There is no support for putting commas in numbers in Sierra Chart.
